Make a drawing and measure the long dimension of each piece. Then measure widths. Make a notation for where mitered edges, finished edges, backsplashes and end caps are. And pick the type of edge you want in front.
Typically it's best to make your own sink cutout after it is installed (unless you are doing an undermount sink installation). And you typically want them to give you templates to lay out and double check everything before they make it.
It's a big project and I don't want to suggest that you not take it on. That looks like a rolled edge that you may not be able to achieve on site.
Most countertop suppliers prefer to make their own measurements. Some use laser technology for accuracy and program the measurements directly into their cutting machines.
However if the only damage is the area shown in the picture you could consider other methods of "repairing" it. You could rout out an area around the damage and inset tiles that will give you somewhere to place hot pots and prevent future scorching. Or a real wood cutting board area that will not dull knives and scratch as laminate will.
The counter you have in your photo is pretty simple and easy to work with. Most home centers stock 4-6 styles of counter similar to yours with a rounded nose and built in backsplash. You can pick them up in the store. Cut them to length and install yourself. They use toggle bolts to hold corners together and they have iron on ends so the exposed end of your counter can be finished like the top.
I have an enclosed porch and I've just striped carpet and two layers of laminate as well as all the adhesive. I have it sanded down and the original tight-grain pine t/g floor looks amazing.
The porch is completely enclosed and surrounded with 17 single-pane glass windows. It has no heating or cooling. It is above a crawlspace that has free access to outside air. So it is protected from the elements but still gets large temperature and humidity swings. It also gets quite a bit of light from the windows, though we do have plenty of trees around.
I'm wondering what type of finish I should use on this floor. Just the same oil poly I use on indoor floors (probably Varathane floor finish)? Is there something more suited to these conditions? I have some Varathane spar urethane which says it is good for outdoor furniture and has UV protection, but it also says not to use in high traffic areas and I get the impression that means floors.
Should I plan to treat the bottom of porch? At some point someone put up fiberglass insulation but that's falling apart and not doing anything. I pondered about spray foam just to seal up the bottom and insulate it some.
Thanks!Read More
Please see photos for the cracks. Is this an indication of foundation problems? I walked the house outside and there is no cracks or damage to slab around the house parameters. Neither is there any damage to external brick. It's a two story house. Thanks
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1124/tile_cracks_436a386a07655a407bc109b5795afd2cd7b4bb53.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1124/tile_cracks_02_e4ce73e64bd23db9fae39bda5c024cad6651f80f.jpg[/img]Read More
