Cracked Tile in Living Room
Old 05-24-21, 01:30 PM
K
Please see photos for the cracks. Is this an indication of foundation problems? I walked the house outside and there is no cracks or damage to slab around the house parameters. Neither is there any damage to external brick. It's a two story house. Thanks
Old 05-24-21, 01:34 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Tile installed directly to a slab, will crack if the slab cracks.
Cracks in your slab, just like a basement or garage are normal.
Is it an indication of a bigger issue, not able to answer that!
Old 05-24-21, 02:05 PM
K
The crack in the tile starts about two feet from the outside wall and the weird part there is no indications of cracks outside.
Old 05-24-21, 04:37 PM
P
Received 2,116 Upvotes on 1,895 Posts
You are probably seeing the inner edge of your footer. Unlike the nice taper/slope to the inner edge of the footer every house I've seen has had the footer with straight vertical sides. I won't say it creates a weak point but it is a great place for cracking where the thick monolith of the footer meets the relatively thin concrete of the floor.
