2-3/8 Floor slope. correct with weight limits
Old 03-01-22, 01:12 PM
D
I have a concrete slab slope of about 2-3/8" and the condo building engineer says the weight using strictly self leveling compound is too much (50-60 50# bags). I was thinking on correcting slope to 1" using compound and then perhaps using different thickness cork to correct the remainder 1" slope. I would then either sand edges or use additional compound to level between the cork pieces. Thoughts? Alternatives? Suggestions?
Old 03-01-22, 03:01 PM
XSleeper's Avatar
Received 1,716 Upvotes on 1,540 Posts
What if you used lightweight? (50% lighter)
https://www.tecspecialty.com/product...-underlayment/
