I bought a house with hardwood floors on the second floor and we have an issue with any liquids spilled upstairs end up dripping down on to the ceiling of the first floor. I am not sure if these floors were installed correctly or not and redoing the upstairs floors is not in the budget. Looks to have 2 layers of 1/2 inch ply underneath. Any thoughts? is this normal and is there anything I can do to prevent this from happening (other than not having spills).
I have the ceiling down in one room downstairs and was considering putting poly up on the ceiling before the drywall...
Downstairs ceiling
side view of hardwood upstairs (from cold air return)
The one time I saw, it was a knocked over full beer.... may have been there for 20 minutes before I saw it. Wiped it up as soon as I saw it and there was a wet spot on the downstairs ceiling....
I Need a reality check. I would like to install LVP over existing hardwood flooring. However, the hardwood flooring creaks and squeaks (worse in the summer). So I want to know if driving 3" decking screws through the hardwood, the subfloor and into the joist (every 4-8" or so along the joist) is a good or bad idea to [u]eliminate creaking/squeaking[/u]. The extra 1/4" of thickness from the LVP on top will be perfectly acceptable and also preferable height-wise, so that is not an issue. I also figured I would drive a 1-5/8" screw through the center of each and every 12-18" long hardwood piece in high traffic areas so that they are more attached to the subfloor everywhere in between the joists as well. Then I would completely work baby powder into the entire floor, before installing over.
I figure this would save me time and money, since I would need to remove the hardwood, then lay 3/4" of additional sub-flooring to bring the height back up to where it is and where I want it to be. The existing subfloor seems to be 1.5" thick at the register vent, and there is only 1 location where the creak seems like flexion over a loose nail, I think the rest of the noise are the individual hardwood pieces rubbing together, but I want to be as thorough as possible and never hear a creak again. I would even consider installing hardiebacker over the entire floor to make it as rigid and noiseless as possible.
Love to hear your thoughts!
Read More
