Laying a laminate floor with an arc
Old 12-14-01, 12:56 PM
Guest
Hi all,
I want to lay a laminate floor that ends in an arc. How do I finish this edge? It transitions to carpet.
Thanks
Old 12-14-01, 01:01 PM
AzFred
"P" Will the edges be exposed? And is this at a junction with "other" flooring or at a change in elevation. (ie a stair)
Old 12-14-01, 01:27 PM
Guest
The laminate floor extends out of a kitchen to a family room, transitioning to carpet at the same height. I can cut the arc at the end of the floor, but this would leave an unfinished butt. I am trying to avoid that. Or should I not care--will the carpet guys be able to cover the unfinished edge?
Old 12-14-01, 05:42 PM
AzFred
Your response indicates that carpet will be installed AFTER your laminate. The carpet guy can place his tackless in a way to hide the edge of the laminate. There is a metal edge trim that can be applied. There is an aluminum Tee transition that will cover both laminate and carpet. That gives you 3 options and will be pleased to provide specifics in an Email if you inquire.
