Tub with a window
Tub with a window
I am in desperate need of a tub surround. The problem is I have a window on the long side of the surround area. I would like to keep this window since it is the only source of fresh air and natural sunlight in the bath. I do not want to tile and I heard that you could cut tub surrounds. I do not know what kind and with what and what type of prep is needed.
Help
Help
you could try using marlite it is widely used in the restaurant industry in kitchens to protect dry wall from water. it is glued and nailed and comes in a variety of colors and has trim pieces to hide nails and seams caulk around the inside and your done...
