Go Back  DoItYourself.com Community Forums > Interior Flooring, Floor Coverings and Coatings Center > Solid Hardwood, Engineered and Laminate Flooring
Reload this Page >
Want to Hide the expansion Space: Sliding Glass Door and Bathroom Marble threshold
Old 03-07-02, 07:25 PM
jimcicci
Talking Want to Hide the expansion Space: Sliding Glass Door and Bathroom Marble threshold
Planning to install Columbia Clic [floating laminate floor]: When these planks are layed perpendicular to a sliding door there will be an expansion gap. How do you hide this space. I thought of using a square nose perpendicaular to the panels to hide the gap. Also outside a bathroom panels will be laid parallel to a bathrooms marble threshold..hide the gap?
Thanks..
Old 03-07-02, 09:18 PM
AzFred
Edge molding is a solution. Metal edge has space for expansion within its dimensions and the limited color choice probably includes the color of the slider frame. A similar solution may work for the bathroom although I cannot picture the site.
