Removing laminate planks
Old 03-20-02, 08:32 PM
AJMCI
I am considering installing laminate on the kitchen floor. However we have a built-in dishwasher that is cut into to cupboard with little room for movement. I am not thinking about installing the laminte under the unit. My concern is if we have to replace the dishwasher someday we will probably have to remove the laminate planks around the unit. Is this the suggested way to remove the dishwasher? Can the planks be removed and replaced easily? Any other suggestions.
Your help is sincerely appreciated.
AJMCI
Old 03-20-02, 09:03 PM
AzFred
I would not install laminate under a dish washer for any reason! Laminate under a dish washer or built in range is a perfect example of wasted money. Does the dish washer have leveler feet that could be screwed up to allow enough space to remove the dish washer? Will the laminate be assembled/installed using glued assembly?
