subfloor for vinyl
Old 04-12-02, 09:16 AM
WGFarmer
Question subfloor for vinyl
Is it ok to use screws to install 1/8" subfloor for vinyl? I only have a 6 X 8' area to do and do not own a staple gun.
Old 04-12-02, 05:27 PM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
I don't see why not; the trick would be to get the heads countersunk so they are EXACTLY flush with the surface. Otherwise you'll get either raised dimples (not driven deep enough) or, later on after some use, pockmarks (screws driven below flush).
Old 04-12-02, 06:15 PM
T
Installing subfloor for vinyl
Any seams and screw holes should be covered with floor patch and sanded smooth. Vinyl requires a super smooth surface for a proper installation.
Old 04-14-02, 10:37 AM
WGFarmer
Thanks for the help.
Counter sunk all the screws and put down floor leveler. Did the trick.
