Vinyl Laminate Flooring
Old 04-20-02, 08:41 AM
rlrcstrs
Is "vinyl laminate flooring" the same sort of thing as a "pergo-type" floor? I was confused when someone mentioned "vinyl" laminate floor.
Old 04-20-02, 11:49 AM
T
Laminate flooring
Generally, laminated flooring products that have a veneer of real wood are referred to as "engineered" wood floors. Products that have a plastic or melamine surface are referred to as "laminates." Laminated products are manufactured by uniting several thin layers together, such as in the manufacture of plywood. Vinyl floor coverings are generally available in sheets, tiles, and planks. If you are considering a laminate floor covering product, go to www.azfred.com for a good overview as well as other helpful information.
