carpet underlay
carpet underlay
I am going to be installing laminate flooring and under the carpet there is a glued down underlay.Is it necessary to remove this before puyying down the flooring. thanks
Installing laminate flooring
Carpet and padding must be removed so that you can inspect and make any necessary repairs to the subfloor. If you are considering laminate flooring, go to www.doityourself.com and www.azfred.com for helpful info and installation tips. Each laminate manufacturer tends to have their own specific subfloor requires and installation instructions. Read and follow carefully to maintain product warranties.
