laminate flooring on stairs
Old 04-25-02, 04:04 PM
paulspad
I recently bought a house and have since decided to rip up the existing carpet and replace it with laminate flooring. I have a couple of questions. Firstly, is the direction in which the flooring is put down matter (parallel or perpendicualr to joists/patio door). Secondly, I was planning on removing the carpet that is on the stairs and also replacing that with laminate. Is there some kind of half round capping for the stair edge, like for real hardwood floors, available for laminate floors?
Thanks,
Paul
Old 04-25-02, 08:27 PM
AzFred
The direction generally chosen for laminate flooring is to have the plank "ends" or narrow side face the primary light source in the room where the planks will be installed. There is "stair nose" molding and it's available in several materials.
Old 04-27-02, 08:34 AM
T
Installing laminate floors
Go to www.doityourself.com/laminate and www.azfred.com for helpful info and installation tips. Each laminate manufacturer tends to have its own specific instructions. Read and follow carefully to maintain product warranties.
