Urgent: Best way to match older oak floors
HI
I'm expanding a room and need to match the 50 year old oak wood flooring and I'm concerned with how to proceed. Does anyone have some tips on how to do this.
This is routine for a professional. A high degree of skill obtained over long periods of time by furniture refinishers, cabinet makers and specialized finishing experts will succeed in an exact match. A DIY may succeed and has an equal or greater probability of total failure. Contact a pro.
I had the same problem earlier this year. My house is 35 years old and we needed to extend the existing hardwood floor about 7 feet (by 14 feet across). My floor was composed entirely of "shorts" and I was also concerned about the match. I went to a local building recycler and bought used flooring. I chemicaly stripped my existing floor, laid the new (used) wood and then sanded the whole thing as normal. Started with 36 grit to even the used strips and blend them into the existing floor, and worked my way up thru the finial screening. I used no stain, just Varathane poly over the raw wood and am very happy. No one that didn't see it before believes it was not installed at the same time. Hint: in the event you can't find used flooring localy new wood will produce the sme results. Good luck!!
I had the same problem earlier this year. My house is 35 years old and we needed to extend the existing hardwood floor about 7 feet (by 14 feet across). My floor was composed entirely of "shorts" and I was also concerned about the match. I went to a local building recycler and bought used flooring. I chemicaly stripped my existing floor, laid the new (used) wood and then sanded the whole thing as normal. Started with 36 grit to even the used strips and blend them into the existing floor, and worked my way up thru the finial screening. I used no stain, just Varathane poly over the raw wood and am very happy. No one that didn't see it before believes it was not installed at the same time. Hint: in the event you can't find used flooring localy new wood will produce the same results. Good luck!!
