installing broken tile porch floor
Old 06-07-02, 06:18 AM
Anne Hester
Talking installing broken tile porch floor
How does one install a broken tile exterior porch floor. The sub flooring will be wood.
Old 06-07-02, 07:14 PM
T
Installing broken tile porch
You install broken tile the same as unbroken, except you have irregular grout lines. If you are breaking the tile yourself, you will have some control over fitting the pieces together like a puzzle.
If the tile is an exterior application, you should use frost proof tiles recommended for outdoors. It is also recommended that tile be installed over concrete underlayment. Any movement in wood floor beneath will result in grout failure and "broken" tiles.
Go to http://www.doityourself.com/ceramic/ for helpful info.
