Sand the whole floor?
Old 06-12-02, 10:44 AM
foul h2o
Question Sand the whole floor?
I am moving into a new home. I am planning on refinishing a wood floor in a bedroom. The floor appears to be in good shape except around the edges look to be lightly stained/discolored from ware. I think the room use to have a rug that left the outsides of the floor uncovered approx 18". Should I try to sand just around the edges or the entire surface? I have tried cleaning the floor with mineral spirits and some of the discoloration came up but there is still a definite line around the floor.
Thanks!
Old 06-13-02, 01:49 PM
Ken fisher
fou:
For best results I'd have to suggest in refinishing the entire area.
Old 06-13-02, 03:12 PM
T
Finishing wood floors
Refinishing the whole is the way to go! For refinishing info, including the National Oak Flooring Manufacturer's Finishing Manual, go to http://www.finishingwoodfloors.com
Old 06-19-02, 08:05 PM
R
You are correct with your assumption of the carpet. The outer floor was exposed to sunlight and wear. If you do refinish it, there will likely still be a difference in the color of the wood. That's just the nature of wood.
