Termite Damage sheet rock
What does termite damage in sheet rock look like? I piece of decorative wood fell off bedroom wall and the sheet rock behind it looks like it has specks of brown granules. I used Liquid Nails adhesive 10 years ago to apply this decorative wood to the sheet rock. Could granules be this adhesive crumbling? The sheet rock has a very small gap (1/4 inch or less) but I have not seen any termites in the house.
Hi Donna. Not a termite expert, although I have run into their handy work much more often than I would like. But I have never seen them go after sheetrock. One of the achilles heals for termites is, they need moisture and you will always find their damage associated with a path to it somewhere. If they can't go through the wood, they build tunnels across the surface, but never walk out in the open.
I think your guess is correct, that this is the aged remains of the adhesive you used.
Hope this helps.
Bud
Hope this helps.
Bud
I'm trying to remember
I've run across termite damage in drywall only once.... I think it was mainly where they had dug thru the gypsum close to the paper making the drywall unpaintable. The damage was over a wide spread area.
I agree with Bud, it was probably the adhesive, termites wouldn't have attacked the drywall and skipped the wood.
