Drilling in front of garage door
Old 04-30-13, 07:29 AM
T
I am puzzled, should I drill in front of my garage door or not? Or inside. I saw 3 houses in the neighborhood
with similar houses as mine. They had termite treatment with holes at 6 in from wall, but did not have hole in front of their garage.
I know I need a continuous parameter. Is it possible there is a water or sewage pipe in front of garage? I know I don't have gas of electricity there canse I called 811.
I do have termites swarmers. But no mud tunnel or other evidence according to 3 pest control inspector. It dose not seem that the garage is another slam.
Old 04-30-13, 07:39 AM
I would drilled them in the floor on the inside and back filled them with morter to seal them up.
Old 04-30-13, 09:08 AM
T
How deep should I drill?
Old 04-30-13, 02:30 PM
P
Received 43 Votes on 37 Posts
We don’t drill across the garage door opening, but we do drill up to the frame/trim. Sometime with a blacktop driveway there is enough of a gap between blacktop and door trim that we can treat into that gap as if it is a hole but you won’t know if it works until you try it.
