Termites visible inside bedroom
What does it mean when you can see a bunch of termites inside your house ?
Are you certain they are termites?
I once lived in a house that was infested. One spring I came home and the whole house was littered with wings. Luckily we caught it before too much damage was done.
If they really are termites you probably have a big problem.
BTW, your pictures didn't make it.
Putting pictures in your post
Whether it's carpenter ants or termites, you seem to have a problem and the solutions are similar. Remove the trim piece and see what's behind it.
Whatever the insect species you need to have it treated as they appear to be eating wood. Usually 99% of what they do is out of sight. So, if they appear year after year it could be quite an infestation. Not good as it can lead to very expensive structural repairs. Have an exterminator inspect your home ASAP.
Picture needs to be more in focus and closer-up but it sounds like it is loose material as opposed to dried mud which would indicate ants of some sort as opposed to subterranean termites. If you live in a location where dry wood termites are present then that possibility needs to determined as dry wood termites do make "frass" and fecal pellets.
We should always include geographic location for insect/rodent issues as that alone can include/eliminate various species right away.
PAbugman
voted this post useful.
That part of the west coast, maybe all of it, is also drywood termite country so you need to get this diagnosed properly. Big difference in treatment and cost between drywood termites and ants. Very different treatments too.
If you carefully sift through the frass, do you find ant body parts? If so, that would indicate ants as the ants will remove their dead along with their chewings.
If you take the "frass" to a local county agricultural extension office, they should be able to ID it or at least send it off for proper and objective identification. They aren't sales driven so they are a good place to start.
