Easy thermostat question
Received 0 Votes
I know this has got to be an easy setup, I just can't find a simple solution. I want to use a thermostat to control a 110v circulator. simple as that, I don't need a hi/lo or aquastat, my temp is controlled elsewhere, just a simple contactor that runs off a thermostat to turn on a 110v pump. What would it be called and where can i find it?
Received 0 Votes
thanks
thanks for the reply, but I should have said that was the first option I thought of, but I already have an thermostat installed that I want to use and I didn't want to run 110v wiring all the way up to that part of the house. I would prefer to use a 24v thermostat, any other ideas?
Received 0 Votes
SPDT Relay?
I am having a hard time finding a SPST relay, can I use a single pole double throw relay? If it wouldn't be easy to do can anyone tell me where I can find a single pole single throw? how about the boiler boss sr-100 relay?
Yeah, you are right, the SPST are harder to find, so yes you can use the SPDT relay, and see you can find them maybe at Ace Hardware, other wise they are on line.
What you mean "how about"? do you mean use this instead of the Honeywell?
