Replaced Janitrol t-stat to a Hunter 44860 on a Goodman ARUF030 heatpump.
I've attempted to replace my t-stat using a Hunter 44860.
The a/c works fine but when I go to heat the unit does not turn on outside and I smell burning.
The original t-stat was a Janitrol with hookups as:
Y-Yellow
G-Green
R-Red
O-Orange
W2-White
E-Brown
C-Blue
The Hunter 44860 has hookups as:
RC/R-Red
C-Blue
Y1-Yellow
Y2-not used
W2-White
E-Brown
O-Orange
B-Not used
G-Green
L-not used
The hunter t-stat came w/ jumper hooked up to RH and the RC/R when I had the burning smell. I removed it and still the heat fan does not turn on. The setting for fan is on auto. Where did I go wrong? I'm not sure if I have a 1 or 2 stage I'm assuming 1 stage. Does it make a difference? The hunter T-stat say up to 2 stage. Does the yellow wire need to be changed or the red?
Thanks!
Problem solved, heat working, setting was not changed on t-stat and hooked jumper back to default setting and everything fine.
Y-Yellow
G-Green
R-Red
O-Orange
W2-White
E-Brown
C-Blue
RC/R-Red
C-Blue
Y1-Yellow
Y2-not used
W2-White
E-Brown
O-Orange
B-Not used
G-Green
L-not used
Thanks!
