Honeywell RTH7600D starts too early
Hi-
I have a Honeywell RTH7600D thermostat and have set it up according to the manual. Now however it wakes at approx 4:30 am no matter what time I set in the wake setup. I have it setback to 62 then wake at 7:30 to 70.
Any suggestions?
ThankS!
Any suggestions?
ThankS!
Is the room temp already 70˚ before 7:30?
Do a reset, and try again.. if it still come on at 4:30, then may have a defect.
The t-stat is suppose to come on early t recovery for you and be at temp of the time you want it to be at.
By reset do you mean reinput in all the waking and sleeping info? I've done that several times. Is there a function to do a reset on the thermostat?
Thanks for the help
Thanks for the help
Ok, no there is no reset, I was thinking of the Pro model touch screen there is a reset.
If you moved the wake time to say 9, still starts at 4:30? If so, then you have a defect, and I'd take it back on warranty.
