Aprilaire Humidifer on ProVision IAQ
Old 02-22-09, 07:58 PM
dinger71's Avatar
Question Aprilaire Humidifer on ProVision IAQ
Hi All,
I was searching the forums and couldn't come up with a good result, so I'd thought I would post it...
I just replaced a Honeywell PC8900 with a Honeywell ProVision IAQ. Pretty straightforward, but the IAQ is not recognizing the humidifier. It's an Aprilaire Model 560.
When I was moving the wiring - the humidifier was wired to the "C" port on the 8900, with another wire going to the lower of the two "HUM" ports. I imagine that the humidifier should draw power when the furnace fan is on, thus the set up.
Is the wiring identical on the IAQ? Right now, I have it wired to the HUM1 and HUM2 ports.
Thanks for any help you can offer.
Old 02-23-09, 06:22 AM
Jay11J's Avatar
For your unit, you need to add a jumper wire from one of the R's on the EIM down to HUM1.
Then one wire from the 560 to HUM2.
Other wire from 560 to C on EIM.
Old 02-23-09, 07:58 AM
F
Humidifier
Did you go into the program and set up the humidifier mode? 0370, 0372, & 0374. It won't work without doing this.
Old 02-23-09, 08:10 PM
dinger71's Avatar
Smile Thanks!
That did the trick. I moved the wires, added the jumper and adjusted the settings on the thermostat. The humidifier came on-line promptly!
Thanks again.
Old 02-23-09, 08:54 PM
Jay11J's Avatar
Glad to hear it's up and running.
Would you like me to go over your settings?
