Help wiring a thermostat!
Old 06-20-09, 07:14 PM
That is the old thermostat, and I got the Honeywell RTH7500 to replace it.
so I wired
(old->new)
R->RC+R (jumped)
B->O/B
Y->Y
G->G
X->C
W2->Aux+E (jumped)
And for function 0170, I selected 7, and for 0190, I used 1.
The problem is that now no matter what mode it is (cool or heat), it would only work as a heater.
Even after switching function 0190's option back to 0, it does the same thing.
Now I placed the old thermostat back and it works like as it was before.
Please help?
PS: old thermostat model is Ruud 41-20804-16.
*more info:
Old 06-20-09, 08:51 PM
Jay11J's Avatar
Everything is set up correct, did you make sure the wire was in place on the t-stat?
Also, do you have extra wire in the wall?
Old 06-20-09, 09:02 PM
Yes, one orange wire and one black wire (presumably O and L).
As you can see in the first pic, it wasn't used for the old one, so I didn't use them on the new one as well.
There has to be something I missed somewhere...
Old 06-20-09, 09:15 PM
Jay11J's Avatar
No, you are not missing anything, I'd suggest adding a wire and remove the jumper wire between E and Aux.
But for kicks, i'd make sure the B wire was tight under the screw set.
do you have a meter?
FYI, I'm off ot bed.. I have to be up in he AM
Old 06-20-09, 09:24 PM
Mmm, same, will try this again tomorrow, I'll keep you posted.
