Weathertron to honeywell help
Old 09-09-09, 09:46 AM
I currently have a weathertron thermostat and i'm trying to put in a programable honeywell. I have to many wires and not sure which go where.
Old wires:
G
Y
X2
B
T
R
W which was same wire hooked to X2
New Thermostat only has:
Rh
Rc
W
Y
G
I tried R to Rc jumpered to Rh
Y to Y
G to G
W to W
the outside unit kicks on in auto but the air is not cool
when you put fan to on position the outside unit doesn't come on.
someone help
Old 09-10-09, 06:36 AM
Jay11J's Avatar
I'm afraid you got the wrong t-stat. What's the model # on the new t-stat?
You will need to get the RTH7500 or RTH7600 model lines to work with your heat pump system.
Do you have an extra wire that is not used.
