Thermostat: 7600D with XR13 and 4TEC3F24
Old 02-20-10, 07:38 AM
K
Any help is appreciated. I bought a new thermostat (Honeywell 7600D) because the old Bryant (TSATBHNHP01-A is on the inside) is failing. I am having problems wiring up the new thermostat and I would like some advice to make sure it is wired correctly.
The system is a Trane XR13 heat pump and a 4TEC3F24 blower. The old thermostat is powered by electrical wiring and does not take batteries. I would like the new thermostat powered electrically and the batteries used for backup/power failure.
Wires coming out of the wall are Orange, Brown, Blue, Red, Yellow, Green, Black, and White.
Old thermostat
O/W2 = Orange
R = Red
Y/Y2 = Yellow
G = Green
C = Black
W/W1 = White
Tan = Not connected
Blue = Not connected
Inside the Bryant thermostat it says
*O = heat pump
W2 = A/C
New Thermostat (heat pump)
C =
G =
Y =
O/B =
RC =
R =
AUX or (W2 conventional) =
E or (Y2 conventional) =
L =
Links to the 7600D quick install and operators manual
Quick Install = http://customer.honeywell.com/Honeyw...=69-2206ES.pdf
Operators Manual = http://customer.honeywell.com/Honeyw...=69-2207ES.pdf
Again, thank you for help and if you have any questions just let me know.
Old 02-20-10, 04:11 PM
Houston204's Avatar
Received 38 Votes on 34 Posts
C = black
G = green
Y = yellow
O/B = orange
Rc & R = red
Aux & E = white (use a jumper wire)
option 170 = 7
190 = 0
Old 02-20-10, 05:30 PM
K
Thanks Houston204. I will let you know if I have any problems.
