Replacing Honeywell T8411 with the Honeywell rth7600
Old 03-29-10, 08:27 PM
Question Replacing Honeywell T8411 with the Honeywell rth7600
I've gathered from prior threads that the rth7600 is highly recommended so I'm going to give it a try. This is my first attempt at a thermostat replacement so I want to make sure I have the wiring correct.
My wiring for the T8411 is:
G - Green
C - Blue
R - Red
W1 - Yellow
Y - None with jumper to W1
L - None
W2 - White
E - Black
B - None
O - Green
There is a brown wire that is stuffed and not connected to anything.
The furnace is a Bryant FK4CNF002 and the heat pump is a Bryant 697CNX030.
What will the wiring set up be for the new thermostat - Honeywell RTH7600?
I appreciate any information anyone can provide.
Old 03-29-10, 09:37 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
Turn off power to the indoor unit before replacing your stat...
G = green
C = blue
Rc & R = red
Y = yellow
Aux = white
E = black
O/B = (I think you meant orange, but the wire that was on O)
set option 170 to 7
190 = 0
Old 03-30-10, 08:02 AM
Thanks for the information and color wiring diagrams. I did check my old wiring and there is a green for G and a lighter (almost pastel) green wire for O. Do I leave the unused brown wire as it is (stuffed in wall)?
Thanks again for your help and feedback.
Old 03-30-10, 12:53 PM
Thumbs up Job complete
Houston204,
Thanks for your help information. My thermostat is installed and everything seems to be running perfectly.
Thanks again.
