Trane XV95 w/XL19i Setup
Received 0 Votes
I'm looking for some advice on the best way to configure my furnace for best performance during heating and cooling. The model no. of the furnace is TUH2D120A9. Any help is appreciated.
Thanks
Stat = Trane----TCONT602A 2H/2C
Dip Switches:
Sw1(staging delay)= 1=off
2=off
Sw2(heat off delay)= 1=on
2=on
Sw3
1=off
2=off
3=off
4=off
5=on
6=off
7=off
8=on
Thanks
Dip Switches:
2=off
2=on
Sw3
1=off
2=off
3=off
4=off
5=on
6=off
7=off
8=on
Where are you out of? Pretty large units for a new home.
Ok, These are the setting you should be at.
Sw3
1=on
2=off
3=off
4=off
5=on
6=om
7=off
8=on
T-stat hook up.
T-stat-----Fur-----A/C
Y1---------Ylo------Y1
Y2--------Y2/Y-----Y2
B----------B/C-----B/C
W---------W1
W2--------W2
G-----------G
Jumper wire at the furnace between O and Ylo
t-stat Installer Setup
1-6
3-0
5-2
6-3
9-2
10-3
31-1
Sw3
1=on
2=off
3=off
4=off
5=on
6=om
7=off
8=on
T-stat hook up.
W---------W1
W2--------W2
G-----------G
1-6
3-0
5-2
6-3
9-2
10-3
31-1
The jumper is giving the blower the correct "profile" speed in the enhanced mode.
Wonder if the dealer has done a Manual-J (Load Calc) on the home??? Your home might off been able to get by with a 80k furnace with 2 or maybe 3 ton A/C. Right now you got 120k and 4 tons.
