Evcon 3600-367P to Honeywell RTH7500D
Received 0 Votes
I have a heat pump with electric emergency heat.
On the Evcon thermostat, I have:
O - White
R - Red
G - Green
Y - Yellow
W2 - White
X - Blue
There is no X on the Honeywell. Where should I hook the blue wire?
Thanks
O - White
R - Red
G - Green
Y - Yellow
W2 - White
X - Blue
Thanks
Welcome aboard.
X is "common", you can use that on C.
Here is how the wires will match.
Old----------New
O - White---O/B
R - Red------R/Rc
G - Green---G
Y - Yellow---Y
W2 - White--Aux w/ jumper to E
X - Blue-----C
System set up menu.
170-7
180-1
190-0
240-3 (If it shows up.)
270-3
Let me know if you have questions on the rest of the settings.
Old----------New
O - White---O/B
R - Red------R/Rc
G - Green---G
Y - Yellow---Y
X - Blue-----C
System set up menu.
170-7
180-1
190-0
270-3
Received 0 Votes
Thanks Jay.
Two things
1. Should R go to R or RC (the Honeywell has both)
2. What do you mean by jumper (W2 - White--Aux w/ jumper to E)? I assume you mean wire Aux and E together? What gauge wire should I use for this?
Thanks
Two things
Thanks
It don't matter.. Either one since there is a jumper wire in place.
You can use a small piece of t-stat wire between Aux and E, and white can land on either one of those two slot.
