replacing lennox thermostatic base plate (Q674L-1355) with a RTH7600
Received 0 Votes
well after lots of research i could not find the info.
So i called honeywell at 1-800-468-1502 but they were close.
So i called them the next day, was on hold for 20 minutes for them to
find out the info for me.
here is the info.
I used the base plate # as there are several thermostats that used the same base plate.
here is the wireing info
old unit new unit
R goes to O/B
Y goes to E
M goes to Y
X goes to C
F goes to G
V goes to R or Rc ( there is a jumper there leave it )
L goes to L
A IS NOT USED ANY MORE
on the old Thermostat
Vr was jumpered to V
E was not hooked up
after installation
function 0170 was set to #7
function 0190 was set to #0
function 0270 was set to #9
hope this helps every one
thanks
Vistec
here is the info.
old unit new unit
R goes to O/B
Y goes to E
M goes to Y
X goes to C
F goes to G
L goes to L
E was not hooked up
after installation
thanks
Vistec
Received 0 Votes
It seems honey well forgot one step
they just call me to inform me
i need to also put a jumper from E on the new unit to AUX
if not the aux heaters will not turn on
but every thing will still work
just will take longer to heat up the place
