How to Wire a XR13h with a TCONT803
Received 0 Votes
I recently found a 803 and want to add it to my new purchased system. I need some esp in the area of aux and emergency heat.
unit is a 4WHC3042A and thermostat TCONT803
K Green
K Green
Did you get the outdoor sensor?
C7089U-1006
Talking about compressor lock out? Most of the time it's around 20˚, most electric can go down to 15˚
Do you also have the performance number under different temps. heat and cool?
Received 0 Votes
I'm referring to the performance data, like 95 outside 80 inside 71 wb while cooling and the btus as temperature outside deceases. I think its something from the dealer website like comfortsite.
K Green
K Green
How many stage is your electric heating coil? 1 or 2? If not sure, what is the model # on the coil?
Install set up menu.
170- 7
180- 1
200- 0
210- 0
220 to 270- 3 (some may not show up)
280-1
300- up to you.
340-2
350-0
360-40
Any other settings you can figure out, if not sure please let me know.
170- 7
180- 1
200- 0
210- 0
280-1
300- up to you.
340-2
350-0
360-40
