Trane xv95 stat
Received 0 Votes
Trane xv95 stat
I have a trane xv95 with heat pump and a Trane XR402 Thermostat. The xv95 has a variable speed blower which can be set, I blelieve, with the current thermostat. The XR402 is not programmable so I have been looking at some new Honeywell touchpad progrmmable thermostats (RTH7600D1022). While the Honeywell Thermostats are programmable, I do not see where they support the variable speed blower. I am not seeing it anywhere in the specs for the stats unless I am just not looking at the right thing. I am not that familliar with the variable speed as well. I think the XR402 has a setting where you can set the Blower at a certain percentage which then determines the blower speed. Can someone shed some light on this for me? Thanks.
Correct, it's a variable speed blower.
That will be a "downgrade" I'd suggest the Honeywell IAQ If you have A/C, humidifier and other things.
Correct. The 400 is the only stat out there that can let you change the blower speed.
The XR402 is not programmable so I have been looking at some new Honeywell touch pad programmable thermostats (RTH7600D1022).
If you step away from the 400 or IAQ, you will lose the dehumidity control for your A/C.
If you go with IAQ, you could gain controling your humidifier, HRV/Vent system, and outdoor sensor.
