Help Connecting My New Honeywell RTH7600d. Please!
Old 11-04-10, 05:19 PM
I have purchased a Honeywell rth7600d and am trying to connect it to my ClimateMaster air conditioning system that has a heat pump. It says it's compatible to heat pump systems but my wiring in my condo seems to be different than everyone else's.
I have:
Green wire-originally connected to my original thermostat at G
Red wire- originally connected to my original thermostat at R
Dark Blue wire- originally connected to my original thermostat at O
Light Blue wire- originally connected to my original thermostat at P...yes P
I only have four wires... NO Yellow or White.
I'm so confused! Please Help!
Old 11-04-10, 05:23 PM
I can't figure my wiring out.
I have:
Old 11-04-10, 05:42 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
What terminal is the light blue wire connected to on your Climate Master?
I'd say Y.
Old 11-04-10, 05:49 PM
thanks for the reply
I opened up the A/C unit and it is connected to the Y, and it turns out I DO have a white wire, that isn't connected to my original thermostat.
Still slightly confused. Shouldn't the white wire be connected? I'll try wiring the light blue to the Y now while I wait for your reply.
Old 11-04-10, 05:56 PM
Houston204's Avatar
I do not see a P terminal in the manual...
Geothermal units rarely have auxillary heat in my area.
Old 11-04-10, 06:06 PM
I don't have Robert Shaw...sorry
I have a Climate Master that I am trying to hook up to my new Honeywell rth7600d.
A/C Unit--------Wire----------OLD Climate Master T-Stat
G---------------Green---------G
R----------------Red-----------R
Y-------------Light Blue--------P
O-------------Dark Blue-------O
W--------------White-------***not connected to T-Stat although connected to A/C Unit
I have it now connected to the rth7600d as and only the fan turns on, nothing else:
A/C Unit--------Wire----------Honeywell
Y-------------Light Blue--------Y
Old 11-04-10, 06:14 PM
Houston204's Avatar
You must also configure your new stat to match your system.
Option 170 = 2
190 = 0
R----------------Red-----------RC & R (use provided jumper)
O-------------Dark Blue-------O/B
Old 11-04-10, 06:19 PM
Yeeeeeeeeeeeeeesssssssssss!!!!
Thank you sooooo much! Cold air in my house in Miami!!!! Yeah
Thanks again.
Old 11-04-10, 06:38 PM
Jay11J's Avatar
Please keep your post in one thread..
I removed all of your same questions on all of the other threads you've started.
Old 11-04-10, 07:10 PM
Jay11J's Avatar
Do you know if your unit has Aux heat kit in it? If it does, then I'd suggest hooking it up so that way you do ahve back up heat in case the HP itself is not working.
