Wiring trouble with new programmable thermostat
Old 11-22-10, 11:08 AM
D
I am changing from an old Honeywell rectangular thermostat to a Hunter programmable thermostat model 44260.
My previous thermostat only had two wires. Black in the "heat" slot and white in the "com" slot.
The labeling diagram shows that a 2-wire heat only systems uses one of the wires connected to the RH terminal and the other wire connected to the W terminal to complete the circuit. In addition, it has a jumper from the RH to RC terminals.
I am not sure if my two wires are compatible with this unit.
Any help would be greatly appreciated.
Old 11-22-10, 11:20 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Just wondering...you didn't say what the problem is. Did you try it and it didn't work?
Does your heat come on when you touch the 2 wires together? What kind of heat is it? Gas, electric? What was the model of the old one?
Sorry for the questions..but it seems like it should be fine...as long as you don't have baseboard heat that uses a line voltage (120 or 240V) thermostat.
Old 11-22-10, 11:37 AM
D
I have an oil burner for hot water and baseboard heat.
I hooked it up and it smelled like smoke.
I just took it apart and a blue piece inside was fried. I will try to post a picture.
Thanks,
Dennis
Old 11-22-10, 05:45 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Was the old Honeywell a 24 volt stat?
Post the model number.
Old 11-22-10, 06:25 PM
D
I am having trouble finding the number. There is a lot of info under the cover, but I don't see a model number.
Old 11-22-10, 09:42 PM
Jay11J's Avatar
Not sure what is the age of your boiler, some older equipment was line voltage (120v), and when you hooked it up to the new stat, you fried it up.
Do you have a meter to check power?
What was wrong with the old stat?
Old 11-23-10, 02:48 AM
D
It is a York heater from approximately 1953.
Old 11-23-10, 02:54 AM
D
I don't have a meter.
I wanted to replace the old thermostat so I could install a programmable to better manage house temperature throughout the day.
For now, I hooked the old one back up.
Old 11-23-10, 05:10 AM
Jay11J's Avatar
Yeah, something that old, I'd say a good chance it's 120 volts. You'll need to get a meter and check the power and find out what you got.
Old 11-23-10, 04:03 PM
D
I reading the info you gave me, I called me heating guy who is an expert on these type of heaters. He confirmed that I do have a 120v line.
He said I would have to see if they make programmable thermostats for that type.
Your info was very helpful and greatly appreciated. I am going to look for a programmable direct volt hookup.
Old 11-23-10, 04:13 PM
Houston204's Avatar
http://customer.honeywell.com/techli...it/62-0278.pdf
The Honeywell TB6575 SuitePRO™ is a good choice.
Old 11-23-10, 07:18 PM
D
I think I found the model number printed on my current thermostat. It is a Honeywell T651A line voltage thermostat, so I think that confirms that I need a line voltage unit.
Houston, if I prefer to purchase one from my local home depot or lowes, because I prefer to not order this type of item on the internet, do I just search for a model that says "line voltage" on it?
If you did not show me that Honeywell that you attached, I would have not known it was compatible because it didn't say "line voltage" in the title, and much of the specifics and terminology is confusing to me.
Thanks again,
Dennis
Old 11-23-10, 07:35 PM
Houston204's Avatar
Jay can offer more help than I when it comes to store availability, but I will check their site.
Old 11-23-10, 07:43 PM
Houston204's Avatar
http://customer.honeywell.com/techli...0s/69-1855.pdf
Looks like the Honeywell RLV430 line voltage stat will not work. That is dissapointing, it looked like their best option.
RLV430
User Guide
Programmable Thermostat
The thermostat cannot be used with the following:
• a resistive load under 2 A
• a resistive load over 14.6 A
• systems driven by a contactor or a relay (inductive load)
• central heating systems
If you do not find one that you like (my initial recommendation was not programmable). You can install a fan center at the unit. This would allow you to use a 24 volt stat.
Old 11-23-10, 08:16 PM
Jay11J's Avatar
Home Depot sells this stat, but as it was pointed out, it may not work on your system.
As said, maybe a relay will be needed to use a regular 24 volts stat.
Old 11-26-10, 06:52 PM
D
I went to a local specialty shop and purchased the only one they had. IT was a Honeywell LineVoltPRO 8000, model # TL8100A1008. I am going to have my electrician install early next week.
I will leave an update.
Thanks again for all the help.
Dennis
