Problem with Venmar 40415 wall control.
I have installed a Broan Hepa 3.1 HRV/HEPA filter (VENMAR HEPA 3100 ) with the 40415 wall control to replace an older Flair (Venmar) that conked-out. When I installed the wall unit, the display started flashing, the HRV started immediately and on the 40415 I could not change settings or get it to stop flashing by pressing any of the buttons. Is the control defective or is there a problem with the wiring (I reused the old wire; the installation manual is very poor and Venmar only has service Mon to Fri 8AM til 5PM!
Any ideas?
Any ideas?
Spoke to Venmar today
I spoke to Venmar support today, they say that I should unplug the HRV, ensure that the switch on the unit is at the "normal/remote" position then replug the unit and this should solve the issue. As the unit is installed at my cottage, I will need to try this next week-end. Of course it appears that the instructions were written by a student, they are not clear and the troubleshooting part is so skimpy. I wish they had clearly stated this.
