After installing thermostat, heat/ac will not turn off
Old 03-21-11, 06:01 PM
I just installed a Honeywell RTH2300 in my home to replace an old mercury unit. It appears to be somewhat working, but the AC/Heat will not shut off. For example, it is set at 75 and the ac keeps running down indefinitely. Also, when the thermostat is switched to the 'off' position, the heating/ac unit keeps running and stays on.
I have read the owners manual and installation guide cover to cover and nothing seems to jump out as something I did wrong. Any help would be appreciated!
Old 03-21-11, 06:39 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
ensure the bare wires are not touching each other
Old 03-22-11, 08:25 PM
Jay11J's Avatar
If you see nothing touch one another. Remove the Y wire and see if it stops. If it don't then you may have a wire shorting out inside .
