Honeywell outdoor temp sensor ...
Old 04-01-11, 09:53 AM
B
I use a Honeywell IAQ 9000 thermostat; I want to instal the compatible outdoor temp sensor (already have it). My only route from the outside to the thermostat is via the multi wire cable from the heat pump (unused wires). The instructions recommend not doing so (electronic noise interference etc). Will it work despite the caution (overstatement?)? or am I wasting my time.
Thanks in advance (you've been a major help in the past!!!!)
Bob
Old 04-01-11, 08:50 PM
Jay11J's Avatar
You can try it and see what happens.. I've seen people posted here and there saying it works. if the temps reading are way off, then you'll have to fish a new set of wires for it.
Old 04-02-11, 05:18 AM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
most of the time you can do that without issues. I get away with running it with the HP wires a lot!
Old 04-02-11, 10:34 AM
B
Thank you for your opinions ...
Bob
