Rheem 422 stat Fan Prog On
Old 06-20-11, 05:44 AM
I have a rheem therm 422 installed. I programmed it to do "fan prog on" for one of the time schedules in the cooling mode. When this time comes the fan starts running, after about an hour it stops and does not start again until the system calls for cooling.
The manual says the fan is supposed to run the entire time during the schedule time. Since it does not does anyone know if this behavior is correct or not, or is this a know issue with this thermostat?
Old 06-20-11, 07:14 AM
Jay11J's Avatar
I am not able to find anything on this model #? (422) Do you have any other numbers?
Old 06-20-11, 08:58 AM
Rheem RHC-TST422DFMS Touchscreen Thermostat
Old 06-20-11, 09:57 AM
Jay11J's Avatar
I am reading the same thing as you. So yeah the fan should run the whole time of this setting, and go back to AUTO after this mode.
Old 06-20-11, 10:19 AM
Any idea why it is not working? Defective thermostat? All other functions work as they are supposed to.
Old 06-20-11, 10:26 AM
Jay11J's Avatar
I'd say it's a defect. Contact the dealer to have it replaced, if it's under warranty.
