No "C" terminal on gas furnace control board
Im installing the wifi 3M-50 T-stat and need to pull a 24vac feed direct from my 1992 Lennox furnace to the Tstats C terminal.
My furnace control board has R, W, Y, G, and T.
Any suggestions on picking up 24vac?
Thanks
Thanks
Jay,
Last tune-up on this unit was performed 10/2010. They did not replace any components.
Thanks for the info on T Terminal, I'll be able to finish wiring this afternoon.
Why does Lennox refer to this as T and not C?
Thanks
Thanks
Has the flapper ever been replaced on it? If not, I'd plan on having ti done.
Lennox was an odd ball system. They did not use the "standard" low voltage hook up like the others did.
