Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Replace White-Rodgers 1F58 with Honeywell RTH3100 - Rheem heat pump
Old 07-23-11, 09:09 AM
I have a Rheem heat pump and indoor coil, models RPKA-030JAZ and RCBA-3765AS17. I have electric auxiliary heat. I am replacing a White Rodgers 1F58 mercury thermostat with a Honeywell RTH3100. I would really appreciate a double check on my wiring.
Here's are the terminals on the old W-R that had wires connected:
B
R
G
Y
W2
Here's how I plan to connect them to the Honeywell:
W-R--->Honeywell
B ----->B
R ----->R
G ----->G
Y ----->Y
W2---->Aux (w/jumper to E terminal)
I have some wire from a 24v wall wart hanging around the garage. It is braided wire, not solid. Is that acceptable to use for the jumper?
Old 07-23-11, 12:22 PM
hvactechfw's Avatar
Received 4 Votes on 4 Posts
all looks ok and yes, braided will work, Prefer solid, but it will work none the less.
Old 07-23-11, 02:07 PM
Jay11J's Avatar
When you go into set up menu, set the heating cycles to 3. It will give you better comfort.
Old 07-25-11, 05:26 AM
Thanks for the help! I'll replace the jumper with solid wire as soon as I get a chance.
Old 07-25-11, 06:48 PM
After wiring the new thermostat as discussed above, I had an A/C service tech out to the house for an unrelated problem. After mentioning it, the tech immediately assumed I had wired the thermostat incorrectly. He changed the thermostat wiring without testing it. He couldn't get the A/C to function and then spent 15 minutes on the phone while someone back at the office instructed him to hook up the thermostat THE WAY I ORIGINALLY WIRED IT.
Thanks to this forum for the guidance to get things right the first time.
Old 07-26-11, 06:20 AM
Jay11J's Avatar
Glad to help you out. Have a great week.
