replacing a trane TCONT401 with a Hunter 44860, help?
Old 08-21-11, 03:24 PM
D
I am replacing my Trane thermostat TCONT401 with a Hunter touchscreen 44860 on a Trane XL16c model 4WCZ6048A heat pump.
Wires on the 401 are
B (think it is common)
O - Switchover
G - Fan
R - 24 volts
Y1 - 1st stage
Y2 - 2nd stage
The question is this, do I need any jumpers as the manual is not clear on this.
I think they should be as follows on the hunter
Trane hunter
B -> C - common
O -> O - Reversing Valve cool
G -> G - Fan
R -> RC/R - 24 volts
Y1 -> Y1 - 1st stage
Y2 -> Y2 - 2nd stage
The hunter came with a jumper from R/RC to RH I want to be sure, we have no supplemental heat as this is a heat pump located in Phoenix AZ
Old 08-21-11, 05:59 PM
hvactechfw's Avatar
Received 4 Votes on 4 Posts
the way you have is good..... You can put the jumper wire in or leave it out, no difference since you have no backup heat.
