How to wire up?
Old 11-11-11, 07:15 PM
How to wire up?
I have a brand new Goodman unit I'm trying to hook up a honey well thermostat 44860 this is whats one the air handler model (ssz140301,avptc313714)
O Orange
Y2
Y1 Yellow
W2 Brown
W1 White
G Green
C Blue
R Red
Old 11-11-11, 07:34 PM
Jay11J's Avatar
You have the wrong thermostat. You want to go up the next model that has the Emergency heat switch. That is the RTH3100C model.
Old 11-12-11, 03:56 PM
the only one I could find is this one the RTH7600 and it says it will work for a heat pump single stage and two stage the only problem I have now is the heat comes on when turned to cool whats up with that.
Old 11-12-11, 08:28 PM
Jay11J's Avatar
Yes, the RTH7600 will work, and also RTH7500. I don't like program stat on HP system. You'll just have to "HOLD" it .
Do you have this new Honeywell hooked up?
Old 11-13-11, 12:16 AM
Yes but set to cool the heat comes on set to heat nothing happens
Old 11-13-11, 05:39 AM
Jay11J's Avatar
In the "System Setup Menu"
170 set to 7
190 set to 0
270 set to 3 (I know the book says 9)
Old 11-13-11, 07:27 AM
I will check thanks jay
