OAT (Outside Air Temperature) Sensor Install
Old 01-15-12, 09:21 AM
X
I have a Bryant 95S furnace with a Bryant Evolution thermostat that supports an outside temp sensor. Since it's optional, my installer didn't bother installing it or even giving me an option, so I thought of installing it myself. It seems like a simple job, only two wires to the sensor that plugs into the board. However, I can't find which sensor would go along with my system. The manual does not specify a part number and it's not listed on Bryant website. Are all temp sensors comparable?
Old 01-15-12, 09:24 AM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
The sensor is automatically recognized in your communicating outdoor unit if it was setup to use it. If you are not using a communicating outdoor unit then a OAT can be installed to the furnace control board. Let me look though my evolution manual and see if I can come up with anything. What is the model of your furnace and outdoor unit?
Old 01-15-12, 09:54 AM
X
Furnace is CNPVP4217ATA, AC is 124ANA030000, and thermostat is SYSTXBBUID01-B. I don't think they are communicating, because when I tried playing the the install menu, it was not able to find the AC unit. Thanks for you help.
Old 01-15-12, 10:05 AM
hvactechfw's Avatar
no, the AC is not communicating. I believe this is the sensor you need. TSTATXXSEN01-B
Old 01-15-12, 10:32 AM
X
great! so was I correct that to install it I just need to plug the wires in their associated slots on the board and perhaps reset the thermostat? It seems I will need much longer wire though. Can I use a speaker wire inside the home for this purpose?
Old 01-15-12, 10:36 AM
hvactechfw's Avatar
yes, add 18 -2wire using wire nuts
Old 01-15-12, 10:53 AM
X
Sorry, got a whole roll of speaker wire, would that be affect the accuracy?
Old 01-15-12, 11:12 AM
hvactechfw's Avatar
it should not, but not a good of quality as solid wire, but you can try it.
Old 07-11-14, 10:23 AM
lawrosa's Avatar
Super Moderator
Received 69 Votes on 61 Posts
old thread. closed..................
