Thermostat with fan timer?
Old 01-17-12, 05:39 PM
I want to be able to run the just my fan for a specific amount of time to help circulate the air in my home. (I donít want to run the AC or the heater, just the fan. ) Does anyone know if there is a programmable thermostat that would also allow me to run my fan for a set amount of time each day?
Old 01-17-12, 06:22 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
honeywell vision pro 8000 series thermostats and higher have an option called CIRC. which periodically brings on the fan a few times an hour. I dont know of a specific stat where it will allow you to program specific times that it will run. WIth the vision pro stats you can also setup in your programming to turn the fan on and off with your scheduled program changes for heating or cooling. Another option would be to use aa additonal programmable thermostat for just the fan using a heating or cooling output.
Old 01-18-12, 09:53 AM
Thanks hvactechfw. I will look into that one.
