MOVED - XL802 thermostat
Old 04-19-12, 09:12 AM
R
Greetings,
I just had a Trane XV95 furnace installed along with a new Trane air conditioner. I also got a new XL802 thermostat. Judging from the settings the installers did a good job of things, apparently, but I have a question regarding the thermostat. It appears that the fan speed does not change along with the schedule. For example, I have it set at 70 degrees for "return home" with fan speed "circulate" and then 65 degrees at "sleep" with fan speed "on". The temperatures changes fine with the schedule, but the fan speed doesn't appear to switch over. Is there some kind of override I am missing?
Last edited by hvactechfw; 04-19-12 at 02:22 PM. Reason: moved post to a thread of its own.
Old 04-19-12, 02:22 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
The blower speed will not change unless the stat calls for heating or cooling. The blower will intermittently turn on and off with the Circ function and it will stay on the entire time when set to ON.
