Honeywell thermostat removal
I have a round Honeywell thermostat used for both heating and air conditioning. It works fine. I have to remove it from the wall to remove the wallpaper behind it. How do I remove it from the wall please? I don't want to start unscrewing screws untill I know which screws to remove. Thanks, Henry
there are three screws holding it on. they should be the only screws holding the stat to the subbase. Then there are 2 screws that hold the sub base to the wall. It is very important that the stat is level when you reinstall it.
Yes they are 3 slightly recessed flathead screws. Leave any torx screws you see alone.
It may be necessary to adjust the temperature setting to move the mercury bulb out of the way.
