Thermostat problems
Received 0 Votes
Thermostat problems
Question does any body know this answer my thermostat room temp is 70f when I turn the stat on to 75f my furnace comes on then almost immediately turns off but if I set it to 85f or higher it stays on any answers please help
kind of...that is not a model number for the furnace. It is located inside the furnace. Beyond that, if you set it only 5 degrees higher than the room temp and it fails to stay running what do you see for a flash code viewable through the window in the blower door of the furnace? Fast flash, slow flash, or flash code?
