Thermostat Wiring Help
Old 11-02-12, 07:03 PM
A
Hi there everyone. I'm hoping someone can help me to wire this properly. I have a Honeywell T6069 thermostat in my condo and belive it's a multi stage heat pump in the building. During the winter the building shuts off the Air conditioning, turns on the heat and in the spring shuts off the heat and turns the air conditioning back on.
The 7 wires coming out of the honeywell T6069 thermostat are marked as follows:
Red - Low Fan Motor
Blue - Medium Fan Motor
Brown - Hi Fan Motor
Yellow - W Note both these wires (Yellow and Orange) are labelled Aquastat
Orange - B
Violet - Valve
Black - L1
The New Hunter I'm trying to connect is marked as follows:
Rh
Rc
Y
G
W
O
B
W2
Y2
A
W3
H
Can anyone guide me on how to connect this?
Thank you.
Old 11-02-12, 08:37 PM
F
Received 36 Votes on 28 Posts
This one is easy but you won't like the answer. The Hunter thermostat is not compatible with your system.
Sorry.
Old 11-02-12, 08:45 PM
Jay11J's Avatar
You can't use the Hunter on this set up..
You will have to leave the stat that's already there in place since it is made for your system that's in the building.
Old 11-02-12, 09:14 PM
A
Really, the hunter model 47377 says it does single and two change heat pumps. Is there any digital model that anyone may know that will work for me?
Old 11-02-12, 09:59 PM
Jay11J's Avatar
You don't have a heat pump.. your set up is using water coil and the landlord is proving that source.
What's wrong w/ the old stat or reason for a change?
Will have to do some digging to find something for your set up.
Old 11-02-12, 10:02 PM
F
You do not have a heat pump, you have a commercial type central heating-cooling system with a fan coil unit in your space. The central plant sends out either heated water (heating season) or chilled water (cooling season) to all the units in the complex. The thermostat operates a valve on the fan coil unit to admit a controlled amount of the heated or chilled water to the coil and the fan (three speeds) then blows across the coil to heat or cool your space under the control of the thermostat.
You will NOT find a compatible thermostat ANYWHERE in the retail marketplace. There MAY be a compatible thermostat available from an HVAC supply company, probably selling only to the trade, but I guarantee that you will NOT like the price.
You MAY be able to talk with your building manager about having an upgraded thermostat installed but be prepared to pay well over a couple of hundred dollars.
Old 11-02-12, 10:08 PM
A
Thank you that's making sense. If anyone knows of a model that I can replace my thermostat with, please let me know the make and model.
Old 11-03-12, 06:27 AM
Jay11J's Avatar
Do you own or rent your home? If you rent, you shouldn't be messing around with this.. As Furd pointed out, talk to your building manager to see if they can offer you an upgrade..
Why are you looking at changing the t-stat?
Old 11-03-12, 07:25 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
You should have the new stat professionally installed if you do replace it...
Old 11-03-12, 05:59 PM
A
I own the unit and wanted to change it for a more modern looking t-stat and more accurate reading and control.
Thanks for your help.
Old 11-03-12, 07:19 PM
Jay11J's Avatar
Houston just posted the models of stat that can work for your set up.
Old 11-03-12, 10:44 PM
Houston204's Avatar
The Honeywell T6069 thermostat will work with 120, 208, 240 or 277 Volts.
The Honeywell SuitePro TB675A1000 will work with 120 or 240 volts.
Old 06-02-14, 10:29 PM
R
hi alex
I'm just wondering if you ever managed to change that Honeywell t6069. I too just moved into a condo am looking to replace this old one to something newer...
If any one out there has a lead please do help !! (Furd, Jay????)
Thanks
Old 06-03-14, 09:03 AM
Received 1,509 Votes on 1,396 Posts
Welcome to the forums.
It was suggested to change TO a Honeywell T-6069. That's not what the poster had.
What to you have there that you are trying to replace ?
