Nest Install with Arcoaire Furnace and Aprilaire
Old 12-04-12, 09:11 PM
Hello,
I have installed the Nest v.2 to an Arcoaire GUA100A016-IN (1987) and would like to incorporate the Aprilaire 440 that is attached to the Arcoaire. Currently Y1, W1, and Rh is connected to the Nest. The Aprilaire has two wires that (there are 3 in the bundle but one is unused) lead to the humidistat. Do I need to install a relay? Also, how will I be able to control the humidity with the Nest? Let me know what additional info would be helpful, I do have the original manuals, etc and can take pictures as well.
Thanks in advance!
Joe
Old 12-05-12, 06:49 PM
Jay11J's Avatar
Is C hooked up to at the Nest?
One wire on * at the Nest, that will then lead to one of the wires on the humidifier, other wire on humidifier will go to C on the furnace.
Old 12-05-12, 08:33 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Why not a pro 8000? Better stat for less money.
Old 12-06-12, 08:28 AM
Jay,
There is no C wire. Attached are the pictures. The bundle of wires from the humidifier has three wires, 2 of which I believe are hooked up. Would one of those be the C wire?
Airman,
Who makes the pro 8000?
Thanks again,
Joe
Old 12-06-12, 09:30 AM
I took some pictures of the Aprilaire and Furnace. The pictures, in order, should start at the solenoid, and the split to the wire to the humidistat. Next, show the wire leading to the furnace. I appreciate all of the help and let me know if you need additional photos/info.
Old 12-06-12, 09:48 PM
Jay11J's Avatar
Those wires looks rough, and I would replace them if you can.
Thanks for the photo, but I can't tell where they all go to for sure.
The two wires for the humdistat is not a C wire one side is hot, then it goes back to the humidifier.
You will do the the wire from the transformer.
Old 12-07-12, 01:11 PM
Thanks Jay. I will give it shot. Thanks again for the advice.
Joe
