Need Help with thermostat
Received 0 Votes
Old thermostat model is Honeywell Chronotherm 3
Wires that were wired in old system
Red Wire - to R
Green Wire - to G
Yellow Wire - to Y1 and looks like jumped to W1
White Wire - to W2
Orange wire - to O
Copper wire - to C
New thermostat model is Honeywell RTH6450/RTH6350
Electric
Red Wire - to R
Green Wire - to G
White Wire - to W2
Orange wire - to O
Copper wire - to C
Electric
Red Wire - to R & Rc
Green Wire - to G
Yellow Wire - to Y
White Wire - to Aux (with a Jumper to E if they are separate terminals)
Orange wire - to O/B
Copper wire - Tape off
You must also configure to match your system.
170 = 7
190 = 0
240 = 3
It should take 5 minutes.
The old stat required the jumper to energize the outdoor unit on demand for heat as well as cooling. The new stat does this without a jumper when it is configured for heat pump operation. (option 170)
Received 0 Votes
Interesting.
Not sure if heat is working fine. When I put my hand over the air coming out it feels a lil bit warm but not hot hot.
When you say option170 I assume for my new thermostat that is the equivalent of Function 1 and I choose heatpump with aux? which is 5?
Thank you for all the help
