3m50 to Wood boiler
Old 01-18-13, 05:26 PM
B
3m50 to Wood boiler
I have a question. I am new to this... I have a Central boiler (outdoor woodboiler) with the following wire diagram. I am try to install a 3m50 and of course don't have a "common wire" . My current wiring diagram is like this:
http://www.centralboiler.com/Tech/C160.pdf
Can I use what I already have to get the common wire or do I need to install additional ac eqipt?
THanks for your help!
Brad
Old 01-18-13, 07:40 PM
Jay11J's Avatar
Do you have an extra wire in the wall?
if you do, then use that wire, and then where does the t-stat wire go to? I am guessing to the Zone valve? if so, then use that same colored wire and piggy back on the #1 screw on the valve, that is oing to C on the transformer.
